This is probably quite simply but I cant figure out.
There is a tree with multiple lists A.
I would like to retrieve lists based on the index number (as shown in B).
So for instance, a list containing all the values in list A, with index 0. (and keeping the tree format),
a list with the values in list A, with index 1 etc…
I know there is the ‘get item’ command, however I would like to do it in a generic way. So I dont have to manually add an get item command if there are more values present, as shown in this example.
Furthermore 1 thing, if a list of the original tree A. has less numbers than the other lists. the output value for these indexes has to be 0.
2020-04-26 Split list in trees based on index.gh (7.0 KB)
Any suggestions?
Thank you in advance
