Hello
Is there a component or plugin to separate two trees in the same list?
i use this method but i want know if there is a more simple way
nb: number of branches is not always equal.
trees.gh (21.1 KB)
Hello
trees.gh (21.1 KB)
There is a component named Divide Branchesin treesloth plugin, but not sure this is gonna work for your purpose…
this split tree does not work for more than 2 branches on the tree is there any other options …
Here’s one way.
Edit: just noticed that Divide Branches component is from TreeSloth plug-in.
Split_Tree_re.gh (18.6 KB)
Kevin
@kev.r Thanks great solution !
Native solution is here using Replace Paths.
And you can use my Unentwine if you need the subtrees.
Split_Tree_re.gh (19.7 KB)
@magicteddy nice i got one native solution to this i just loved your magic plugin…
This would fail for variable tree branches, but if you connect the C output of the first Partition List to the S input of the third, it would work properly I think.
@magicteddy is there any way you can share the plugin file for “Unentwine”, I am not able to locate or download from the web
