I am trying to split a Brep with a Delaunay Mesh. Is it possible ? I can’t figure out a way to cut my brep except from a plane or a curve or a surface.
Does anyone has an idea ?
Thanks a ton in advance and happy new year to everyone !
Well I’m not very familiar with components thus I don’t know if the Method Brep.CreateFromMesh is available (if it is replace the first thing with native GH stuff: that yields the cutter for the split).
For the split part either use the 2nd thing or as an excersize try (for solid results) to use 2 times the native component in the red group (swap cutter with brep for the “cap”: meaning that the brep splits the cutter in order to get the “cap” brep) and join the pieces in order to get solids as results.
NOTE: obviously you sould position the cutter in such a way that actually splits the Brep in 2 valid pieces otherwise the split is meaningless.
C# deals with breps lists and checks are more elaborated
Pure Native GH Components solution left unfinished just before the last step: take the challenge and combine the right pieces (splitted and breps for the cap) in order to get your solids.
