Speckle lets you quickly share Grasshopper 3D models online with just one double click.
Developed by D/A/S, while working at The Bartlett, UCL Faculty of the Built Environment, within the InnoChain project.
Author here. Happy to announce that speckle grew up a bit:
The big news:
Online viewer:
Embedding in websites:
If you want to embed the models on your website - as you can see it’s done on speckle.xyz homepage - it’s really easy! A little “get embed code” button is planned, but until then you can follow these steps:
Take the link Speckle gives you, ie. http://speckle.xyz/view/15wyBk/, replace the view with embed, so it looks like this: http://speckle.xyz/embed/15wyBk/ and use this as the “src” for an iframe.
The final code you can paste in your website should look like this:
<iframe src="http://speckle.xyz/embed/15wyBk/“ height=“500” width=“500”>
Zooming won’t work in embed frames so you can actually still scroll the page down. TODO: will add zoom in and out buttons in the embedded viewer.
URL Hacking to toggle options:
You can toggle on or off some options, by appending to the speckle viewer link the following:
You can, of course, combine them (order is not important):
http://speckle.xyz/view/jxvak4/g1p0s0e0
This will make sure the grid is on(g1), disable the ground plane(p0) and shadows (s0) and turn edge display off (e0). Works as well for embedded viewers.
Named Views:
Speckle exports together with your geometry, all the Named Views from that are defined in the Rhino document. Check the bottom option bar of this model: http://speckle.xyz/view/15wyBk/
You will see the named views defined from Rhino: Top, Flemish Theatre, StKatherine, Overview.
Clicking on them will bring up that specific view! Handy if you want to guide your collaborators/clients towards specific points of interest.
You can also enforce the model to directly load on a specific named view by appending to the url the “v”+view number (counting starts at 0). For example, let’s say I want to enforce the “Overview” view in the model linked above. It’s view number 4, and since counting starts from 0, that means i need to append v3 to the url.
Voila: http://speckle.xyz/view/15wyBk/v3.
Note: I understand this is a bit of a stupid way of doing things, especially if you’re not a geek. So it might change in the future…
Other news:
Code will be released in the public domain soon, hopefully (need to clarify with my current employer, UCL, all the ins and outs). Furthermore, I need to cleanup the server side application from hard coded server secrets and it should be yours.
Always looking to get feedback! Drop me a line with any requests/curses/questions. I don’t know how to stress the importance of this for me - i promise to give you a free cookie for every feedback email I get! -
Don’t forget to join the grasshopper group to stay in touch!
