Hello all, just to let you know that the Spacemouse/3dconnexion settings that we are using for Rhino inside Revit are reversed (Rotation, Zoom, Left, Right, etc) in the regular Rhino 7.
It goes both ways, setup your settings in Rhino 7, use Rhino inside Revit, reversed.
Any clue where that might come from ? It’s fine in Rhino WIP
The controls are different in Rhino vs Revit, spacemouse must be only using the Revit settings since Rhino is operating inside.
I’ve never used a spacemouse/3dconnexion, hopefully someone with experience can chime in.
Spacemouse is using the Rhino settings when it’s opened in Revit.
I just tried to change the settings live and it inverts everything between Rhino 7 and Rhino inside Revit, live.
You just solved it, why would that setting be different in Rhino inside Revit, noboby will know.
At least now, people will know how to solve it.
Thank you
