3D Connexion Space Mouse Inverted
For some reason the 3D Connexion is inverted when running Rhino8 compared to how I run Rhino7 and other programs. In properties it is requested to change via the 3D Connexion software however if I do this then Rhino 7 and my other programs are then inverted. This is preventing me using Rhino8 without having the change settings each time I use it and then have to change back to use the other programs.
run the command _spacemouse. and select object mode:
Fantastic thanks so much @tay.othman Works great now🙏
