Sometimes some edges are not visible
… not even when selected
Hello - is this a selection of the top level object, not a sub-objects? And is it a polysurface, extrusion, block instance… or?
thanks,
Hi Pascal,
I managed to isolate it. Check if it looks the same on your machine. On mine it shows very strange in all viewports. This extrusion was created in Rhino 5 and opened in 6, and saved in 6 again. I 5 it has no problems.
https://wetransfer.com/downloads/a109b326e2981d8a9c8a334b57bd62a620171212210859/c2e5e93fce73ad234d6672dd2f7fccf220171212210859/52acf6
171212 edges.3dm (236.2 KB)
Hello - yes, it looks wrong here as well - I see that it is far, but not all that far, from the origin… looks OK at the origin. I’ll put this on the pile, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43074
RH-43074 should be fixed in the latest BETA. Those edges ought to show up now. Please give this a try.
