I hope I’m not the only one who sees it. Every time I open Document properties, regardless of whether I change any settings or cancel and close, next thing rhino does is rebuilding shading meshes. Why…? It happens here every time.
I haven’t noticed it earlier working on light stuff but now I’m dealing with heavy solids and shading wireframe model takes couple of minutes on my dated machine. Really hope this is a bug and not new added feature…
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 12Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GT 640 (NVidia) Memory: 2GB, Driver date: 12-3-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 460.79
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-3-2020
Driver Version: 27.21.14.6079
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Next Limit\Maxwell for Rhino\maxwell_rhino.rhp “Maxwell for Rhino” 5.0.6.3
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
Hello - the first thing to check is whether disabling Maxwell and SimLab in Options > Plug-ins page and then closing and restarting Rhino, makes any difference - make sure only one Rhino is running when you do this.
Hi Pascal, I followed your suggestions and disabled both plug-ins. No difference. See video below. Interestingly mesh regenerates itself only after opening Mesh panel. Any other settings does not affect it. Although after disabling both plug-ins mesh did regenerated itself too.
And speaking about meshes. The image below shows one big solid. The client wants to 3D print it. Rhino 7 on my dated machine takes 36 minutes to shade it…!! Same with Rhino 6. Rhino 5 does it in 30 seconds. Editing this geometry in V7 or 6 is impossible.
