Rhino Shading Issue
Whenever I go and open Rhino everything is fine. As soon as i change the screen to shaded the entire model turns bright white with no definition. The sun and light features is not on and the material is default, it happens no matter if the settings are default or changed, just started up or halfway through. is there any fix?
As a first step to identify the cause, can you run the command SytemInfo and paste the result in a reply here?
-Willem
Rhino 6 SR7 2018-7-18 (Rhino 6, 6.7.18199.22081, Git hash:master @ 123fa928529aea2697d4d286dda5f63a029d2a71)
Licence type: Educational Lab License, build 2018-07-18
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: SEARCH-307-14
GDI Generic (OpenGL ver:1.1.0)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 0.0
Shading Language: Not supported
Driver Date: (null)
Driver Version: (null)
Maximum Texture size: 1024 x 1024
Z-Buffer depth: 32 bits
Total Video Memory: n/a
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.7.18199.22081
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.7.18199.22081
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
Hope this helps!
Hello - this looks pretty suspicious - as though you do not have a video card - what is the installed video card or chip, do you know?
it looks like one is not installed and another computer that the program works on has info on the card. That could be the solution.
