Some regressions in render window
Regression
When you zoom in using the scroll wheel, the image is centered on the cursor position.
Rhino 8 has the image locked to the top left so you then have to use the scroll bars to find the point of interest.
Regression
The window doesn’t remember that you have saved an image. It will prompt you to save when you close the window.
It used to remember.
It’s not setting the window title.
Wish
Let us pan a zoomed image via right click drag, just like the viewports in the main window.
I see that, thanks for reporting, see also linked yt below.
this is on the list as RH-55901 Rendering: Zooming and panning not really working well in the Render Window
I don’t get any popup asking me to save the image here in Rhino 8, nor in Rhino 7
Maybe you have the, "“In the future, do not show me this dialog box.” checkbox checked?
I did a render and used the toolbar icon to save the file.
Then I pressed the red X, close button, on the top right (I’m using Windows) and was given the prompt above.
I noticed that the window title doesn’t change after a toolbar button initiated save.
It is still, [Unnamed-13] instead of, whatever I said the filename should be. (looking in my folder, I can see that it was: “v38-0032-r8.png”)
okay, that makes sense, I will look. I suspect this is a single issue, since it doesn’t get a name, it also doesn’t register that it is saved already.
RH-78938 Saving a rendering does not update the name in the render window
