Rhino 8 - Closing minimized window from taskbar issue
The issue happens when there is unsaved changes, here is the way to reproduce the issue:
  1. open Rhino8 and edit(eg. add geometry like arc)
  2. minimize the window
  3. right click on the task bar icon and click close window
By doing this, window with message “Save changes to untitled?” doesn’t show. And Rhino8 freezes that we need to end the task from task manager. (Rhino7 doesn’t have such issue)
The version is Rhino 8, 8.11.24254.15001
It is not critical but would be nice to be fixed. Thank you.
Best regards,
Yung-Yuan Chen
I can reproduce that, but:
that I don’t see. I can Maximize again, hit Esc and close Rhino normally
Hi @Gijs,
Thank you for checking this. Yes, I can confirm that I can maximize it again. But I couldn’t operate before I hit esc afterwards. I think you provided a workaround for it. Maybe we don’t need to hit esc when the first issue solved.
