Some Items issue with visibilty
Hi All,
Im having issues with unhiding/showing some objects. some are perfectly fine and visible but others are only showing surface edges… see below:
Any idea how to resolve this? only happens in rhino 8.
Thanks,
Mo
Could you share this 3dm file? Thanks.
you probably used SetObjectDisplayMode on one or some of the objects, set it to view and see if that helps.
Brilliant!! Thank you enecephalon, this has fixed the problem!!!
