Hi there, while working with Rhino 5 suddenly all my custom scripts (e.g.: mainly scripts loaded from @Pascal Golay and others from the McNeel website) stopped working. The aliases still auto-complete, and the command appears in the command line, but no command is executed and no commandline menus are shown.
Interistingly if I try to run the RunScript comman the commandline shows an “unknown command” prompt…
I really need to get this sortet out asap so any help would be highly appreciated.
Okay that was fast.
I realized that somehow the RhinoScript plugin had unabled itself. That was what caused the problems I re-enabled it, restarted Rhino and… Voilà!
Sorry for the hassle… might be useful for someone with the same problem in the future though.
Indeed, that is what happened.
I was repeatedly using Pascal’s script, to create different versions of a bent steel rod structure, when without any apparent reason the command stopped to work.
I litterally used the script on some lines I created (and it worked), then I created a slightly changed layout of lines and arcs, wanted to fillet them again with Pascal’s script and… Boom, no luck.
I wasn’t really aware that RhinoScript is a plug-in, that was why I didn’t find it disabled immediately.
