I’m having trouble with the script plug-in since last update to 6.11 /resetup my system.
I’m used to having trouble while using Matrix Software and Maxwell Render on the same Rhino 5 (second licence as both softwares are not yet available for Rhino 6) as they share dlls.
Now when I start Rhino 6, it tells me that the plug-in “Rhino Script” failed to load and even if (every 7th time) I don’t get the error message, I’ll encounter the following screen when I try to run a script.
I’ve made all updates for Windows7, .net frameworks etc, just not for Matrix.
Didn’t find anything in the forum.
Anyone encountered a similar problem?
When we have seen this happen in the past, it was always related to an anti-virus program blocking this plug-in. Are you running something other than Windows Defender?
Thank you for your reply.
No, I’m not running any other Antivirus programs, but a Windows Defender definition update cannot be done by windows. Might this be a indication to be a malware?
Good thought, but already checked that. I tried to stop using the plug-in when Rhino starts and restart it manually. same error.
tried keep using the plug-in, same error
another indicator could be that if I rightclick on the opened Rhino6 logo down in the windows bar (in my old windows 7 x64), it would show “Rhinoceros 5.0”
I tried to uninstall, reinstall, redeinstall , repair. None of these seemed to work. It was the main reason why i reset my whole computer including windows.
I was asking myself if there could be an better or worse order in which all these software should be installed.
I did that way. rhino5 comes with matrix and was installed through the matrix launcher thing installer. then matrix, maxwell and its thino plugin and then rhino6
no, not allowed by the mouse symbol… like a round interdiction circle
doesn’t work with files either. I run with admin rights
Well, little edit:
It now ( at this very moment) works fine so I can’t test it, but it’s a repeating error that bothers me since long time and seems to switch on and off randomly. I use Matrix software very rarely and it seems to appear when I used it and switches off some time later.
However, I can live with these miner problems and that software mess at the moment, hoping for updates to rhino 6 from the plug in sides soon.
I don’t blame any of the programmers guys, I’m not very surprised that this mess of different softwares and plugins don’t work properly all together.
