Hi - anyone has a good solution for the wires showing through for GH preview objects problem ?
The rest of the scene displays OK, but when zoomed in a bit the GH-only objects start showing all edges.
TestZBiasFactor doesn’t help to solve this…
In Rhino5 you can try disabling the Bump Preview from the canvas toolbar rightmost button dropdown. Although if you know about TestZBiasFactor you probably already know about bumping.
Hi David. V5 - and - disabling Bump Preview did the trick! Thanks… it’s been a while since I had a project that gave me opportunity to use Grasshopper. Clearly got rusty and had no idea about that switch.
