Hei Oskar - trying here with a similar scene, and the RhinoPDF printer, everything seems to be working as expected. Could you both share the scene you are working on (simplified to include only those items that are needed to reproduce the issue) and run the Rhino SystemInfo command and post the results here?
Thanks!
How do I share a scene? If i try exporting the things im working on the draw orders change and I dont get the viewports exported, so everything is different.
There also seems to be a general problem with draw order in the file as the bringtofront and sendtoback are being very quirky and giving different results every time. (I’m not using blocks btw)
Please update to the current Service Release, which is SR13. I would try that first - Rhino 6.8 is a long time ago, and there have been fixes in this area if I’m not mistaken.
wim
I would try to get someone at the university to update the installation.
A quick-ish work-around would be to select these white hatches, extract their borders (DupBorder), and then use these new curves to trim the curves that should be under the hatch.
HTH,
wim
Yes this will be what I’ll do in the end, it’s just that I change the objects and placement overtime and have to redo the process several times. But it will definitely work for the final.
OK, in that case, I would probably do it the other way around.
For example, make a rectangle (that represents the living room). Then make a few rectangles that represent a table and chairs. Select all, turn on History, and then run Hatch. Pick a pattern that represents the floor boards.
When you need to change the placement of the table and chairs, select the curves for these and move them - the hatch will update automatically:
