We are battling Rhino 6 printing issue with hatches. None of the hatches show in the PDF or any print what so ever. Screen shot is showing the hatches (attached) and the PDF print keeps hatched areas blank. Is there any solution to this?
Thanks, Robert.
When I open that file and look for hatches, there are none. I can’t find any in model space or on the layout from which you showed a screen shot - and that detail looks like this on my end:
How can I get this file in a state where I can see the hatches - or, better yet, can you post a file in the state that it needs to be in?
Also, if VisualARQ is somehow involved in this file, we should probably change the category for this thread so that the correct people can have a closer look.
The viewport is tied to the section D and all sections were purged to make file lighter.
Attached is in the link is the original file. KS4134 - Forum.rar (10.8 MB)
I still can`t print in any format with the hatches. As a reference I am attaching the AutoCAD PDF shop drawings that inherited all Rhino hatches and they work with no problem.
@robert.dvornicky I could print some of your pages to pdf with Rhino 6, VisualARQ 2.12.5, and the Rhino PDF printer with no apparent problems. See the results attached:
VisualARQ is up to date and we use Bluebeam Revu CAD for PDF printouts. Rhino PDF and Primo PDF do not work either. Also, hatches do not appear on .jpg and .png printouts.
Hi Robert, that’s weird. Can you share the screenshots of the other Print Setup settings, (View and output scale, margins and Position, etc…)?
That way I can see if we have anything different.
