Snapshots move object
Hi forum, I haven’t used snapshots much, but here recently using it more. Is there any way to make it work with a rotated object? It works nicely if you move an object and save it. Move it again and save it. If you want to go back to the first save, it acts s expected. If you were to rotate it with a snapshots and save, try going back to the first snapshot. The object goes flying off screen before returning to the desired location. I understand I am wanting something that Bongo does. What would it take to have snapshots rotate an object and look like it is on a hinge? Thanks, Mark
Hello - Snaphots does not know how an object was transformed - it only knows position/orientation at each end of the transform and makes up its own tweening.
