I am using Rhino 7 on Mac and every time I try to utilize Snapshot and its animation feature it either crashes or loads indefinitely
Is there a solution?
hi @Seyla_Dillon can you run_SystemInfo in Rhino and post back the results?
systeminfoseyla.txt (4.4 KB)
Not sure if this an option for you, but Rhino 8 will perform a magnitude better on M3 Max.
I’ll look if I can reproduce it on mine here, but better if you can share a file that shows the behavior.
