Hi All.
Does anyone know if the animation section of the mac WIP snapshot command is working ?
The one where it translates between snapshots as opposed to the scrolling through still images of snapshots ?
On line says to double click the snapshot once you have turned on animation but it isn’t doing anything.
Also where do I report bugs manually ?
Cheers
G
nathanletwory
(Nathan 'jesterKing' Letwory)
November 28, 2018, 9:11pm
2
Moved to #serengeti:mac
Are you on latest WIP? It’d be useful to get the results of the Rhino command _SystemInfo in a reply here.
Check publicly visible snapshot bugs to see if already something is logged. This bug has already been reported though as https://mcneel.myjetbrains.com/youtrack/issue/RH-49484
Reporting you can do here (someone will log them to the YouTrack system), or do it yourself at https://mcneel.myjetbrains.com/youtrack/issues
Hi.
Thanks for the response.
So is Snapshot animation supposed to be working ? I think that’s my main question.
I updated to the latest WIP just before I tried the snapshot command.
I’ll post the system info command tommorow
And thank you for the reply.
Now for the biggie.
Will snapshot work with keyshot as it’s renderer ?
That would be flipping amazing
nathanletwory
November 28, 2018, 10:43pm
4
It is supposed to work, but it currently doesn’t - it is a bug. I linked to the bug report for that. Once that gets fixed it should work again, but that is not in the current version. Some future version, hopefully fairly soon.
edit: I don’t know about Keyshot, you’ll have to ask the Keyshot people about that
Ahh that’s great thanks Nathan.
I wasn’t sure wether I was trying to make a function that wasn’t available work.
Look forward to the big fix.
Should I still report it or is it under way as you say it is in the system ?
Re keyshot would it not be a mc neal thing to use key shot bridge snapshots for the Animation or is that not how it works ?
nathanletwory
November 29, 2018, 4:58am
6
It is already in the system.
Generally third-party devs are responsible for integrating their tools into Rhino themselves (or use contractors to do so). We provide the SDKs and support.
Great thanks for your help.
