Hi, I would like to know how many other users of Rhino8 for mac experience problems.
I am using a Macbook Pro M1 Max - 64 Gb / 4Tb - OS 14.4.1 - 2022. Running the latest update of Rhino 8.
I have waited for Rhino 8 to come out before buying a new Mac for the reason it would be working without issues on the Mac OS silicon platform. (Metal)
However I seem to be running into issues.
Earlier I had some crashing issues with a file that was 1.6Gb …I managed to reduce the file to 1Gb and it seemed better.
Then new issues appeared. Initially when these issues occurred I thought I solved it with re-installing Rhino 8, but issues have returned.
- an object drawn as a solid, changed into seperate open surfaces.
- I can not snap to these (and other) surfaces. it snaps to a far distant undefined point. ??
- clicking on surfaces highlights arrows from the edges to inside of that surface.???
- I also can not delete certain surfaces…
- This happens now on multiple files.
- autosave is frequently and it takes about 30 sec to save, which is annoying.
I have purged, without result
No bad objects
Rebooting macbook doesnt help.
Re-install Rhino 8 doesnt help.
I tried to move back to Rhino 7 on an older mac mini with intel processor 3GHz-6core, 64 Gb, Catalina OS 10.15.7, exported the RH8 file to RH7 .
Then the file is fine, I do not have the problems that I have on RH8 on the M1 macbook pro M1 Max, however the file is a lot slower than in R8.
Are there any known issues with Rhino 8 for mac when it is installed on a M1 macbook? (64Gb Ram).
Is Metal not doiing its job?
Do you advise to move away from mac and buy a dedicated windows computer? Is Rhino still not usable on a Mac?
I would really like genuine advise wether this is a ongoing Rhino issue, a Mac issue or that it is a fixable issue? I desperately need to finish some jobs and this is holding me back big time…
