Thank you Gijs!
Having the same issue as Brady. Except it’s happening on shaded views as well. The problem isn’t as bad in R7, but this has been an issue I’ve noticed to varying degrees even before R7.
I’ve also been having the same problem, in R8.
This also happened in R7 every now and then.
I’ve figured that it happens after I change to Ghosted mode, and then it starts snapping to occluded objects on all the other modes. “Snap to occluded objects” is off. I try toggling it, no luck.
Funnily, the problem is fixed while I turn on the Ground Plane, and comes back again when I turn it off
