How can one slice & cap pipe ends at 45 degrees?
This example was made 11 years ago using rhinoscript.
Now I would like to do it with Grasshopper.
Any leads?
https://i.imgur.com/n4twSDf.jpg
If the pipe was based on a curve, place a Frame (Plane) at the end of the curve, rotate it nn degeres, Cut & Cap :
(I cheated with the distance from the curve ends (red dot). That distance better be calculated depending on the angle and pipe radius):
Split And Cap Pipe Ends.gh (15.6 KB)
// Rolf
Thanks a lot, I will try to reverse engineer it, I am toitaly new to grasshopper.
