Single object deleting slow
Hello Everyone.
Would need some help on one issue .
I’m using a file that suddenly takes much time (like 7seconds or more) to execute simple command as:
  • deleting even one object
  • making a boolean substraction on a simple set of objets
some other command of object creation does not make problem though
Would Someone have an idea of how to solve the problem? or maybe what’s the hardware element that would cause the problem?
Yours sincerily
Vincent
Sorry you’re having problems.
Please run the Rhino “SystemInfo” command and post the result.
That will tell us what computer resources Rhino is seeing and hopefully will suggest a change.
Thanks
thanks for your fast answer an excuse me for this really late answer.
Here is the Systeminfo :
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Corporate, build 2023-12-12
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
*Computer platform: DESKTOP *
  • Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 12GB, Driver date: 9-12-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.42*
  • Accelerated graphics device with 4 adapter port(s)*
  •    - Windows Main Display attached to adapter port #0*
  •    - Secondary monitor attached to adapter port #1*
OpenGL Settings
  • Safe mode: Off*
  • Use accelerated hardware modes: On*
  • Redraw scene when viewports are exposed: On*
  • Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)*
  • Anti-alias mode: 4x*
  • Mip Map Filtering: Linear*
  • Anisotropic Filtering Mode: High*
  • Vendor Name: NVIDIA Corporation*
  • Render version: 4.6*
  • Shading Language: 4.60 NVIDIA*
  • Driver Date: 9-12-2023*
  • Driver Version: 31.0.15.3742*
  • Maximum Texture size: 32768 x 32768*
  • Z-Buffer depth: 24 bits*
  • Maximum Viewport size: 32768 x 32768*
  • Total Video Memory: 12 GB*
  • C:\Users\Vincent\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0*
  • C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino” *
  • C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351*
  • C:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit” *
  • C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351*
  • C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351*
  • C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI” *
  • C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots” *
  • C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351*
  • C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351*
  • C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse” *
  • C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement” *
  • C:\Users\Vincent\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”*
Any idea?
Vincent
Hi Vincent / Daniel -
You are running a cracked version of Rhino, and I would venture a guess, also a cracked copy of V-Ray.
That’s always a possibility as well, of course…
hello Wim,
Actually No.
We have 2 licences for Rhino and 1 for Vray.
Do you think it would be right to reinstall everything?
And Yes Sorry,
Im Vincent, but my manager is Daniel Gibbons and owns the account .)
Hi Vincent -
How big (both in MB on disk and number of objects in the file) is a file typically when it starts showing this behavior.
What happens when you disable V-Ray in the plug-in manager and restart Rhino?
100 MB on the disk
22 block instances, 8 curves, 64 surfaces, 37 polysurfaces, 9 extrusions, 52 meshes, 3 SubDs
see screenshot attached.
Please have Daniel contact sales, there is a problem with his account. Thanks.
Hello Japhy,
+34 933 199 002 and tech.eu@mcneel.com right?
Yours sincerily
Correct, Not a big deal but something he should clear up. Thanks
