Sine wave like a crown gear
Hi all,
I’m trying to create a “sine” gear. I tried Sweep2 and Loft. Is there any way to make the green cylinder to follow the purple wave or any other way to make a guide?
What I’m trying is a sine wave that follows the red circle/surface.
Thank you,
Ludwig
Sine Wave Cylinder 20 Objects.3dm (449.4 KB) Crown-Gear_example
you can markfoci and get the center point of the circles, then do selpt, then crvthroughpt to generate a curve that goes through them.
then use ribbon offset to make the surface
