Hi Rhino users,
I need to bend a wave around a circle, not necessarily at this diameter. I tried the bend command but it didn’t work.
Any help is welcome.
Ludwig
Sine Wave.3dm (55.6 KB)
Hi Rhino users,
Ludwig
Sine Wave.3dm (55.6 KB)Hello- Flow
should work.
Hi Pascal,
Thank you for the fast answer. I tried all the options in Flow
, didn’t get the results. The Flash animation is not working in Help File.
Hello - it should do something like this, depending upon which base line you pick.
Dear @ludwig_19_91
Depending on your intent.
Bu using Flow, if the original linear Sine Wave Curve does not have the same length as the target curve, the final result may lead to a hybrid Sine Wave.
Helix + AroundCurve option may help to better get a more concrete result.
Regards
Rodolfo Santos
