Washer spring
Hi Rhino users.
I wonder if it is possible to roll a sine wave or create a washer spring in Rhino.
Hello - this kind of thing?
Exactly!
Hello - try this -
Make a circle, Deformable option, with the point count divisible by four ( for four waves, adjust to taste)
Move the curve control points up in quadrants
Scale2d a copy outward or inward, and Loft between the two circles. It mat be handy to use History so you can easily adjust.
If you need more precision than that - i.e. some actual sine wave shape, then there may be more hoops to jump through.
SpringWasher.3dm (48.6 KB)
Pascal,
Thank you very much. I didn’t understand completely. What I’m trying to make is one valley and one ridge around a circle. Is it possible?
Hello - yep, it should be possible - see if the attached is it.
SpringWasher2.3dm (108.5 KB)
Yes, it’s.
Thank you!!!
