Simple Sweep
What does the “Simple Sweep” Option do on Sweep2?
I do not see it in the help files.
Hi Jim - under the right conditions(The rails match, the section curves are placed at matching Edit Point locations only.)
the result will be a surface that has the same structure as the rails and section curves. Generally it is for users who have set up good matching curves and do not want the resulting surface to be refit, with multi knots etc.
When is the simple sweep option enabled?
