Less Surface ControlPoint after Sweep2
lessCps_start_rh6.3dm (1.3 MB)
dear @MohsenMohammadvali
you may want to check the forum for “simple sweep”.
not sure if this is possible for closed cross section curves.
you may want to split the cross sections in two curves - both touch the rails at edit-points.
after 2x _sweep2 use _matchSrf as a backup to make sure you do not have a kink between the 2 surfaces
kind regrads - tom
