I have a set of cylinders that extrude just below a surface (from a curve), I need to cut just the top off of them. At the moment the circles are even with the surface as well, I’m sure there’s an easy solution, I just can’t find it.
Thanks
-Paul-
Thanks
-Paul-
Hi Paul, try the Split command. Pick the cylinder to split and use the intersecting surface to use as cutter. Follow the command line prompts. It should do it. —Mark
That’s what I was looking for, worked perfectly…
Thank You
-Paul-
