Simple Polysurface Geometry into single surface for use with GH
I am working with the grashopper surface morph module that requires a surface input. The shape I am looking to have the texture applied to is made of a few surfaces that will not merge without modifying the geometry, it is made of straight lines and arcs to create a pill shape.
If I apply multiple surfaces to the module, the applied texture shows a different scaling for each surface.
I am unsure how to resolve this.
I have a lot of experince in Rhino, but very little in Grasshoppper.
Any insight is greatly appreciated.
Pill Shape.3dm (1.1 MB)
Pill Shaped Surface Contour.gh (35.6 KB)
  • Jon
Pill Shaped Surface Contour_re.gh (39.7 KB)
You Rock @HS_Kim
May you be blessed for your generosity.
Thank you!
