Attached is a simple GH definition with a polysurface that results from a revolve of a contour curve. It is part of a propeller hub/shaft arrangement. When this polysurface is used as input to a Surface parameter, the results are weird: a trimmed circular surface. I would expect that a Surface parameter cannot accept a polysurface as input. Is this a bug?
I’m guessing (won’t know for sure until I get to a genuine computer at the office) that the polysurface yields naked edge curves which are then planar-surfaced. One of those weird confluences of type conversion function feeding off of each other.
Yeah I can confirm that the conversion fails from Brep to Surface, so then it tries to convert the original data into a curve, which works because there’s only a single naked edge loop, which then becomes a surface because it is planar and closed.
Try using the Revolve Unsplit component from Pufferfish. It will generate single untrimmed surface even if the input curve has kinks and then you will be able to use it in gh as a surface rather than Brep (if you bake it into Rhino it will bake as a polysurface though unless you turn off crease splitting in Rhino)
