ShrinkWrap Grasshopper component multiple times slower than Rhino command
I suppose that one of the first things that ShrinkWrap does is meshing the input geometries. Using the same ShrikWrap settings, the Rhino command in my tests was multiple times faster with the same input (hundreds of extrusions and Breps) than the Grasshopper component.
However, when I manually meshed the inputs, the Grasshopper component was performing as fast as the Rhino command.
I think that the Grasshopper ShrinkWrap component might produce unnecessarily dense meshes when it has to convert NURBS to meshes compared to the Rhino command.
SystemInfo
Rhino 8 SR7 2024-3-28 (Rhino 8, 8.7.24088.06001, Git hash:master @ f39d2478d0e77eb325f46d0c6d8cfc8754fe44b2)
License type: Commercial, build 2024-03-28
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\ShrinkWrap.rhp “ShrinkWrap” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24088.6001
shrinkwrap compare2.3dm (8.3 MB)
shrinkwrap compare2.gh (23.1 KB)
That’s a very interesting point, any updates from the DEV team ?
I have a YT open to get a method in RhinoCommon that will allow Grasshopper to take on a pile of mixed geometry and process it into meshes like the command uses. There was an edge case issue in the way Extrusions are getting handled that still needs to be addressed. This is likely what you’re running up against in this particular instance.
https://mcneel.myjetbrains.com/youtrack/issue/RH-77155
Cool, thanks for having it tracked
