Show hidden corner color
please help how to
display color separately? please help
Hello- there is no provision for that , if I understand you, other than in ‘Technical’ based display modes which have hidden lines
thank you! i tried but it doesn’t work like in your picture.
does ghosted or xray mode do what you are looking for?
no i want to see it in mode, sahded
ok, then pascal’s suggestion is your best bet.
i have followed pascal but it doesn’t give the same result?
Hello- have you set the viewport display mode to Technical?
Thank you but maybe you misunderstood what I meant. i want to change the display color when i catch the point on the hidden edge
I hope you watch this video, you will easily understand what I mean.
Video_2022-05-06_224604.rar (176.6 KB)
Ah - no, as far as I know ‘osnap highlighting’ only uses object color.
i wonder if rhino developer have any solution to do that?
Hello- can you describe what problem this would solve? I can only think it would become more difficult to identify the snapped geometry.
if that can be done, it will help me to orient the edge that i want to work on that object further.
@noithatchiaki I think maybe I understand what you are looking for -
Is that correct? The difference is between polysurfaces and extrusions.
If you convert the box into a polysurface (ConvertExtrusion - or Explode/Join) you will get the desired behavior, if I have understood correctly.
I don’t mean like that.
