Panda_ASW
(yangdaoqian)
1
Hi,all
I have defined a new type called ZLKJ_SECTION inheriting from CRhinoCurveObject and overwritten the ShortDescription by “ZLKJ_SECTION”.
But in rhino when The object was selected ,the ShortDescription is not “ZLKJ_SECTION” but “Curve”.
What did I miss?
dale
(Dale Fugier)
2
Hi @Panda_ASW,
Please review, closely, the following SDK smaple
If I build and load this plug-in, it works as expected when you select a marker object.
– Dale
Panda_ASW
(yangdaoqian)
3
Hi,@dale
I found miss point that I forgot to register the event watcher!
Many thanks!
