Hello to all! When I move the mouse over a tool, a small window pops up with the description. In my case, the window is displayed, but unfortunately no description. What could be the problem? I have already tried resetting to factory settings and reinstalling Rhino. Unfortunately, nothing helped.
Hi Felix -
Please run the Rhino SystemInfo command and copy-paste the result here.
Thank you for the quick reply. Here is the info:
Rhino 7 SR27 2023-2-1 (Rhino 7, 7.27.23032.13001, Git hash:master @ 4a0030c0d354560df03764f4f49ecc5d119e5118)
License type: Studentenlizenz, Build 2023-02-01
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3080 (NVidia) Memory: 10GB, Driver date: 11-13-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 526.98
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-13-2022
Driver Version: 31.0.15.2698
Z-Buffer depth: 24 bits
Total Video Memory: 10 GB
C:\Users\felix\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22334.1442
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.27.23032.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.27.23032.13001
Thanks, Felix -
Does this behavior change when you disconnect one of the monitors? You’ll have to restart Rhino when you check this.
I have now tried it, unplugged the screen, closed Rhino, restarted the PC. Unfortunately no change.
Thanks for trying that.
I don’t think I’ve seen reports of this issue before, which would mean it’s probably something specific to combinations on your machine. Two other things that you could try: (1) update the GPU drivers for the RTX 3080 (check the Rhino Notifications panel to see if there are any links for updating the drivers), and (2) disable the 3rd party plug-ins and restart Rhino.
Thanks!
