Wiley
December 23, 2022, 9:02pm
1
I am trying to create a widget that has exactly the same function as a mapping widget, where it records scaling, rotation and spacing of a pattern.
As opposed to a 3d box like the mapping widget, I just need a 2D rectangle widget which looks like the mapping widget with its dashed thickened lines and colors.
One should be able to rotate, scale and move them, but not deform the rectangle.
And upon selecting, the type would be pattern widget. (as in “1 pattern widget added to selection”)
Any advice on where I can begin with this task? @dale @stevebaer ?
Wiley
December 24, 2022, 3:11pm
2
This is my current but failed attempt at it.
public class CustomPoint : CustomPointObject
private Color clr = Color.AliceBlue;
public CustomPoint()
public CustomPoint(Point3d at) : base(new Rhino.Geometry.Point(at))
public override string ShortDescription(bool plural)
return plural ? "Widgets" : "Widget";
protected override void OnDraw(DrawEventArgs e)
e.Display.DrawCircle(new Circle(this.PointGeometry.Location, 1.0), clr);
e.Display.Draw3dText(new Text3d("sdf", new Plane(this.PointGeometry.Location, new Vector3d(0, 0, 1)), 1), clr);
//base.OnDraw(e);
protected override void OnAddToDocument(RhinoDoc doc)
base.OnAddToDocument(doc);
protected override void OnTransform(Transform transform)
base.OnTransform(transform);
protected override void OnPicked(PickContext context, IEnumerable<ObjRef> pickedItems)
if (clr == Color.Black)
else
clr = Color.Black;
base.OnPicked(context, pickedItems);
protected override void OnSelectionChanged()
base.OnSelectionChanged();
protected override IEnumerable<ObjRef> OnPick(PickContext context)
return base.OnPick(context);
Edit: I have figured out most of it.
Wiley
February 5, 2023, 12:33am
3
public class GradingCurve : CustomCurveObject
public GradingCurve()
public GradingCurve(Polyline curve) : base(new PolylineCurve(curve))
return plural ? "Grading Curves" : "Grading Curve";
//base.OnDraw(e);
else
clr = Color.Black;
Revisiting this topic again.
While I can change the name of the CustomPointObject, I don’t seem to be able to call the ShortDescription() method with CustomCurveObject.
In the prompt it is still showing as closed curve, as opposed to Grading Curve, which I have set.
Can anyone shed any lights on this?
@dale
dale
(Dale Fugier)
February 6, 2023, 10:51pm
4
The top of the What
output reads “Grading Curve”, which is what your method returns.
– Dale
Wiley
February 6, 2023, 11:11pm
5
@dale
Thanks for replying!
But the return in the prompt still says “1 closed curve added to selection.”
As opposed to
“1 Grading Curve added to selection”
It’s quite inconsistent isn’t it?
dale
(Dale Fugier)
February 7, 2023, 12:44am
6
I see the issue when selecting a single, non-point custom object.
https://mcneel.myjetbrains.com/youtrack/issue/RH-72837
– Dale
brian
(Brian Gillespie)
February 8, 2023, 12:10am
7
RH-72837 is fixed in the latest WIP
Wiley
March 7, 2023, 10:09am
8
Same thing happened to CustomGripObject
public class SampleCsRectangleGrip : CustomGripObject
public bool Active { get; set; }
/// <summary>
/// Constructor
/// </summary>
public SampleCsRectangleGrip()
Active = true;
/// <summary>
/// RhinoObject override
/// </summary>
return plural ? "rectangle points" : "rectangle point";
base.OnDraw(e);
e.Display.DrawPoint(this.CurrentLocation, PointStyle.Circle, 1f, System.Drawing.Color.Red);
OnDraw / ShortDescription / OnSelectionChanged events are not triggered at all testing with the SampleCsRectangleGrips in rhino-develop-samples
e.g. I tried to change the grip style by overriding the OnDraw EventHandler, but fails to do so in CustomGripObject
@dale
Wiley
March 16, 2023, 11:52am
9
push this as this is still unresolved.
Wiley
March 16, 2023, 4:27pm
10
The reason I need this is because I need to override the OnPick handler to have a larger PickContext for a CustomGripObject.
As it is now when the CustomGripObject is embeded in CustomObjectGrips, all the eventhandlers are not called.
