Shortcut/toggle for turning off edges/isocurves/mesh edges/curves in view
Is there a way to quickly turn off all of these (or some) elements in a view? trying to avoid having to go to the panel, finding them, unchecking them, panning around, then go back to panel, finding the categories, then checking them again. Tedious, right?? Thanks!
Hello - none that I know of - if you work primarily in one display mode it may be simplest to make one or more alternatives with these set as you like and simply switch modes.
that’s a good workaround. Thank you.
