Is there a better way to toggle show isocurves instead of going into the options and unchecking the show isocurves box. if possible id like to be able to toggle it with a hot key.
This answers the first part.
Use can use -Properties to access it via the command prompt so you should be able to make a macro.
Thank you.
@Tommy804 you can also toggle these from the Display panel - that will affect the current display mode - a shortcut to how you are getting there via Options; Dan’s method will affect the selected object.
Do you know if there is a similar way for Toggling the Show mesh wires option that you can get to through the command line so i can make a macro for it?
