Hello
The shortcut keys do not work since the OS was changed to Windows 11.
For example, the one that does not work now is ctrl+alt+R for rendering, but it does not work.
I have the keyboard set to this command.
'_SetDisplayMode _Rendered
best
Hello
best
Hi Jack -
Have you tried a “Repair” of the Rhino installation in the Windows Control Panel?
Hi @wim
I tried restoration, but the result was the same.
Wireframe and shaded work.
If you select from here, it will render correctly, but shortcut keys do not seem to work well.
Apparently it was interfering with other software hotkeys.
hi,I found the same problem… can you tell me how to solute it? THX
Hi -
Please describe the issue with some details.
Also, run the Rhino SystemInfo command and copy-paste the output here.
Hi.
Same problem after installing the new Nvidia App.
Solved by disabling Nvidia Overlay inside the App (Settings → Features)
