Ctrl+Alt+S does not work for enabling shaded viewport.
All others are ok but only shaded mode is not.
What could be the reason?
I appreciate any help.
PS: I am using the trial version of 7.
Hi Sirin -
Have you checked the shortcut in the Rhino Options > Keyboard section?
If that is as it should, what does “does not work” mean? What does the command line read? You also might want to run the Rhino SystemInfo command and copy-paste the result here.
Hello Wim,
Thanks for the reply.
By “doesn’t work”, I mean there is no response in the viewport and on the command line.
Here are my results :
Keyboard:
SystemInfo:
Rhino 7 SR10 2021-9-13 (Rhino 7, 7.10.21256.17001, Git hash:master @ 68677dc86520a0de9485d8b8fa2e841e757733f3)
License type: Evaluation, build 2021-09-13
License details: Stand-Alone
Expires on: 2021-12-20
Windows 10.0.19041 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 7-24-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 431.70
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-24-2019
Driver Version: 26.21.14.3170
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 7\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.10.21256.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.10.21256.17001
I hope those help to find the solution.
Hi Sirin -
Could you post a screenshot of your display modes in the Rhino Options dialog box?
I’d update these drivers to the latest. You can find links to the NVIDIA page from the Rhino Notifications panel.
Hello again,
Updated Nvidia and below my display modes:
But I guess the problem is different because I realized that after 3 consequent trials this window pops:
Hotkey is assigned to this and Rhino cannot takes over it. Either IT dept cancel that relation or I will define a new combination.
Thanks for your time.
