Thank you attention
1.- Yes, when it comes to doors and windows, you can change the style and profile (width and height). For example, if I have a hinged door and I want it to have the same properties as another sliding door, the dimensions and style would be changed, the sliding door would be left with the dimensions of the door that I want. With this same principle, the windows up to the element styles, in other words, would be applied to all the visualarq elements.
2.-yes, that’s what I had thought, and there is no other way without placing the path curve. let’s imagine a common case, a floor plan arrives from autocad or any other software and the walls have hatch, I would like to select the visualarq walls command and then all the hatch’s of the walls and finish in 2 clicks raising all the walls with visualarq objects , this is an example that would not only apply to autocad but even plan finder floors or some automated floor layout solver
