Shortcut for new layer and assign selected objects to that layer?
in my current workflow I create some new geometry , then I select it. I then goto layers and create a new layer. then I select the new layer and right click to change object layer.
is there a quicker way?
I have this:
! -_ChangeLayer _Pause _NewLayer
If geometry is selected, it will prompt you for a new layer name and then change the selected geometry to that layer.
I also have this if you want to move a copy of selected geometry to a new layer:
! -_CopyToLayer _NewLayer
yes! do you have that stored as a short cut or a new command somewhere?
I set it up as the right click on the ChangeLayer toolbar button.
thank you
hello Helvestosaur, i wonder if you can help me again.
I want to setup a new shortcut F key like before. But this time I need to do the following:
I want what I have selected to be asigned to a new material (not layer like before)
so use a new custome material (next one in list) - can you please help?
can anyone please help with this?
