I am working with a shell structure, and for some reason I am not able to convert to mesh. I don’t have a surface either. How do I go forward?
The Grasshopper file is attached.
Sicli Factory_1.gh (32.8 KB)
Hi, try to connect the curve to ‘Loft’, and then ‘MeshBrep’. There is the built-in MeshBrep, or MeshBrep (Karamba3D) if you want to analyse it as a shell later.
Hope it works.
Hi again,
I’ve tried to follow your suggestion, but it doesn’t work. Able to send me a solution proposal?
Hi @ahmadals,
Here is one method to loft the 3 curves.
Sicli Factory_1-mt.gh (61.9 KB)
Could you please remove Karamba as a tag from this post, because this question relates to a general Grasshopper issue rather than a Karamba specific? Thank you
Hi @matttam ,
Thank you for the solution.
I think Karamba is removed as a tag now. Please let me know if it is not removed.
