Im trying to split a rectangle with several lines with shatter but I can’t
What Im trying to get is
in individual segments like this
I’m going to appreciate your help
yes the point was understand how the shatter component works and how can I structure de data
Shatter isn’t really the ideal tool for this though. You’ll have a really hard time figuring out which opposing shatter segments belong to the same region. I think if I weren’t allowed to use SrfSplit, then I’d probably try a Sub Curve approach. But even then you’ll be in a world of hurt trying to deal with the special cases of the corners and jumping the rectangle seam point.
Surface Split is a single operation on all curves at once. The output cannot be trusted to be in some sort of meaningful order. You’ll have to sort the results, probably using distance to a base point/line of the region area centroids.
Ssplit.gh (20.3 KB)
ps. I share your frustration about how difficult this is. It definitely feels like it should be a lot easier.
Rhino has a nice command Curve Boolean, not sure how that logic might be incorporated without a mouse click though.
you are totally right, I’ve working in other projects with a lot of components and I was thinking How I cant be able to split a rectangle with some lines but it is part of grasshopper easy as you want or the several ways to get one result. Thank you Sr.
