Shatter / split help
need some help splitting multiple polylines with a bunch of points. i guess shatter is the way to go, but i simply can´t figure how to filter only the wanted points for each curve and pass their parameter to perform the split. the points have been pulled to the CVs of the polyline, so they are exactly in the right position.
any help appreciated, thanks in advance
shatter_splt.gh (86.2 KB)
i also tried Riccardo Majewski´s split curve component, but it does not work as wanted on polylines.
shatter_splt_re.gh (67.3 KB)
thank you so much !!
You can also use this
thanks to you too!
even more compact.
