I’m trying to bring in the shared parameters of a series of wall panels to use them as attributes through the Elefront components but for some reason the Element Parameter component is throwing nulls when reading the value of the shared parameter?
See attached image, the referenced Guid should return the Panel_Tag (WP1 etc.)
The elefront Guid component is referring to Rhino Object Unique id’s.
The shared parameters will be available via the Query parameters. If you need to you can also see what’s available using the Shared Parameter Component and Parameter Identity Component, not that getting the GUID is necessary but if there’s a parameters of the same name i can see how that would be beneficial.
My issue seems to be with being able to bring in Shared Parameters from the Revit File. In Revit the Shared Parameters have values but when I query them in Grasshopper nothing comes through?
Here’s what I’m trying to accomplish:
Layout Panel families on fabrication layer (done)
Use shared parameter data from Revit Model (panel_Width, Tag, etc.) to set Rhino attributes with idential names
Push new generic model families back to Revit on fabrication layer with shared parameters intact and able to schedule (Geometry goes in fine, cant get parameters to work.
I’m using the Inspect component there. You can use Shift to expand to all the elements available parameters, any parameters that you wire into a panel will stay when you collapse the component using CNTL and click the component Icon.
The output is the value but will also cast to Parameter Key if need be.
Looking at this more, it’s expecting a particular data type (not text), so either getting the parameter ID as shown or passing through the Rhino GUID is required.
