Hi all,
I’m hoping to access the built-in instance parameter Width for the windows in my Revit file. I plugged the element into the Element Parameter component and connected the Width parameter, but it returns a null value. I plugged the element into the Inspect Element component instead, and no Dimension data is displayed at all when I click into ‘All Parameters’.
I remember this working before, and when I open the parameter information in Revit there is a number associated with the width of each window.
Has anyone come across this issue before? Could something be blocking Rhino.Inside from accessing this information in the Revit family, or am I doing something silly?
I’m using Rhino 8, Rhino.Inside 1.26.9083.18516 and Revit 2023. TIA!
