Here is a macro that triggers a specific number, eliminating the need to write it manually in the Command line. It’s handy that two of these could be added to a single icon. I use it to set two of the most common offset values in my workflow. I also made a custom icon for it.
If you only include a number in the command field of the icon, it will be entered in the Command field as soon as you press the icon.
Left mouse button command:
2.6
Right mouse button command:
0.2
However, if you want to add a waiting for additional confirmation, adding the “\” symbol behind a number in the command field of the icon is what does the magic.
2.6\
0.2\
32-bit PNG with transparency (32x32 pixels)
2,6 и 0,2 мм.rar (929 Bytes)
In a better World, Rhino will have this functionality implemented directly in the commands that use manually entered values. I made such a proposal at the end of the 1st post here:
