Notilus AI v1.3.0: turn plain-English prompts into Rhino scripts
Hi everyone,
we’ve just released Notilus AI v1.3.0, our AI scripting assistant for Rhino 7 and 8. You describe what you want in plain English, and Notilus AI writes a Python script, runs it in your model and saves it, so you can run it again on the next project.
notilusai-prompt-to-geometry
What’s new in v1.3.0
  • Redesigned panel with a light and dark theme that follows Rhino’s appearance
  • Prompt card with hint text, character counter, viewport toggle and Ctrl+Enter to run
  • Live status: a progress bar and status line while the script is generated and, if needed, fixed
  • Saved scripts as cards with run, edit and delete buttons, a run counter and search
  • New edit dialog to rename a saved script or edit its prompt (Enter saves, Esc cancels)
Also new since v1.1.1
  • Newer reasoning AI model
  • Self-correcting scripts: when a script fails, the AI gets the real Python error together with your request and fixes it automatically (up to two retries)
  • It knows your model: units, tolerance, layers and the current selection go with every request, and one click attaches a capture of the active viewport so the AI sees what you see
  • One-step undo: every script runs as a single undo step, and failed attempts are rolled back before a retry
Works on your selection
Select objects first, then ask. Here the floors are colored by height, with the viewport capture attached:
notilusai-selection-and-viewport
Saved scripts
Every script that runs successfully is saved. Rename it, search for it and run it again instantly, without a new AI request:
notilusai-saved-scripts
Three prompts, no code
Create a twisted tower of 30 floors: each floor is a 20 x 30 m box, 3 m tall, with a 0.6 m gap to the next. Rotate each floor 3° more than the one below around the tower axis.
Color the selected floors by height with a smooth gradient from deep blue at the bottom to orange at the top.
Label every fifth floor with a text dot placed 4 m outside the tower on the +X side, showing the level and elevation, e.g. L10 +36.0 m.
All media were recorded in Rhino 7 with live AI requests. Only the wait for the AI (8 to 15 seconds) is cut from the GIFs.
Getting started
We’d love your feedback, good and bad, and to hear which tasks you’d like to automate. Questions or demo requests: info@notilussoftware.com
Thanks,
Tahirhan
